read title.
FYI…its the same motor in grand prix, corsicas, and maybe grand ams.
M&M you pull it will be your friend…
$99 with a 30day warranty
Im sure they will have one
and cavaliers, bonnevilles, celebrities and yes grand ams,
Yes, its a newer style 3x00 tho, don’t get stuck with an older flat top 3.1, but I’m sure you knew that, just my 2 cents.
yeah i knew. i didn’t know what other car it was in, but i knew there were compatible ones.
already called m&m they told me $187
L82
The L82 (“M-code”) was an updated, SFI version of the MPFI LH0, produced from 1993 through 1999. It featured a structural oil pan, a stiffer redesigned engine block, and sequential fuel injection. Output for this version was up 20 hp to 160 hp (up 15 kW to 118 kW) at 5200 rpm and 185 ft·lbf (250 N·m) at 4000 rpm. Compression Ratio for the L82 was 9.5:1 and the bore measured 89 mm (3.5 in) while the stroke was 84 mm (3.3 in) giving it a displacement of 191 CID (3,136 cc).
Applications:
- 1997-1999 Buick Century
- 1994-1996 Buick Regal
- 1994-1996 Chevrolet Beretta
- 1994-1996 Chevrolet Corsica
- 1994-1999 Chevrolet Lumina
- 1997-1999 Chevrolet Malibu
- 1993-1997 Oldsmobile Cutlass Supreme (1993 received both LH0 and L82 3.1 L motors)
- 1994-1999 Pontiac Grand Prix
- 1994-1998 Pontiac Grand Am
- 1994-1998 Buick Skylark
- 1994-1998 Oldsmobile Achieva
- 1995-1999 Chevrolet Monte Carlo
this is correct right?
Yes. I have one but wont be able to pull it to the summer time. Has 60k miles it has been well maintained. I got the car 5 years ago with 40k miles on it. It out of a 95 beretta. Oil changes whre done every 3k miles with mobil 1.
get a 3400 and get a little more power…
and the bonneville never had the 3.1L
And yes, those look correct.
Yeah but trying to find a good low milage 3400 for under 400 is hard around here. Belive me i tried.
Make sure you get one from a corsica or beretta … or else whoever is doing the swap will be changing ALOT of parts over
these motors change every year and with every car
I have one, $2000 and it comes with a malibu and a clean title.
