I am looking for a threaded barb fitting to tap my oil pan with. I can seem to find anything in the 3/4 size i need. can anyone help me out?
didnt we already go over this a month back.
there isnt enough meat to tap in the civic pans… safely.
I assume you need a 3/4 NPT thread of an oil return? If so I might have the correct size weld bung on my shelf, and can TIG it on the pan, just about anywhere you need it. PM me if you are interested.
OR, I have a bunch of 1/4" thick round punch slugs of aluminum I use to weld on catch cans and what not, so when you drill and tap, you have 1/4" + what ever thickness material you welded it to to get plenty of threads cut in to hold very well.
I also have the 3/4 NPT tap set, so what ever you decide to do, I can do it for ya. so PM me.
Both solutions are the best.
Did you try www.MSCdirect.com ?
I have seen numerous fittings jb welded in without problems. But welding a bung in would be a more correct way of doing it.
EFFFF that, leaving a snail trail of 10W30 behind your car when it comes loose SUCKKKS!
lol
OP, ill weld that bitch on there right for you for pennies. get at me man.
krazy i am not questioning what you are saying but i have had a tapped pan for 6 years with no problem other than location. or it can be welded i just dont have an insane amount of time. I dont need an npt fitting it just has to have a thread on one end and a barb fitting on the other. I dont have the ability to drive it too far due to the oil problem.
no offense taken man. ![]()
I still dont understand exactly what you need?
one of these?:
Male 3/4 in. NPT to -12 AN Hose Barb
if so they are $5 from summit. I might even have them here too… ill have to look.
i have d and b series tapped pans which do you need?
i need a d but it has to be in the correct location. the one i have now makes the return sit on the down pipe and every 2 years it burns a hole in the oil line. i have tried everything else.
i have a y8 pan thats already drilled and also a fitting for a -10 line. PM me if you want it cheap . Have my old shit just laying around that I dont need anymore…
i will shoot a pic of were its at tommorow for ya.
thanks guys this is all a great help. i dont have a tap set that is this large and this has been a pain for me for years.
I do, like i said. Bring me the pan, clean. I will weld a slug on it where ever you please, drill and tap. Collect 20 dollhairs and send you on your way. ![]()
ohh and my shop is 15 minutes from you if you are in Ballston Spa… right off exit 8 or 8A, on Rt 9.
This.
