WTBorrow: Jeep ECU and/or ICM 94 cherokee
just need to test by swapping out a few parts. An ecu to test would be really nice. The thing can’t seem to get spark and fuel at the same time from what I’m “told”. I haven’t even looked at the car myself yet. I’m suspecting the ASD relay went bad but the guy tells me he swapped out 2 of the three realys (ignition, fuel pump, and ASD) saying they were all the same part number (which I think is odd because I would think the ASD would be a normally closed relay which would then open if a problem occurs) Reguardless of all this jabber, I’d like to go out to his house with spare parts to try. The motor is the inline 6 and I believe all the ECUs for those are same. Any help would be appreciated, and if that is the problem…you will get $$ for the ECU if you are willing to sell it.
