I really do not want to sell my car but sadly there have been some things I need to take care of and no longer have the time or money to finish this car.
The chassis is in pretty good condition I would give it a 7/10
This is a quick rundown of whats done:
VG30DETT swap (engine can be seen running in car)
Stock 300ZX side mounts w/ custom intercooler piping
Dual HKS SSQV BOV
Custom exhaust downpipes
Megan Street Coilovers
JDM rear non hicas subframe w/ Solid Rear Subframe Bushings
Walboro 255 Fuel Pump
What is needed to complete:
Custom driveshaft
TT ECU with tune (can use stock TT ECU if you figure out how to run a dual intake on stock ECU)
Rad Fan
Modify shifter to line up with chassis (I can show you what you need to do, not a big problem)
Need to make a custom y-pipe to be able to attach to a S13 catback
Most of the interior has been torn out to save weight, I still have all the interior pieces which will be included with sale
The car should be ready to go after those things are done.
The pic I have posted is when I was working on the car last year. The car is currently under a cover so when the rain stops I will pull cover and take more pics.
Given the condition and the amount of work put into this car I would like to get $2500 for it as is. I could also do $2000 without the coils.
