Ok I am fairly certain it is this, and also I think I was wrong it is a 51" not a 52"
Sony KP-51WS520 51" Hi-Scan 1080i HD-Ready Projection TV
* 51-inch high-definition-ready rear-projection television with DVI and HDMI digital-video inputs; 47.13 x 53.5 x 25.75 inches (W x H x D)
* CineMotion 3:2 pulldown detection and reversal removes redundant video information to display a film-frame-accurate picture from movie sources
* HD Detailer wideband video amplifier ensures that the fine details contained in a high-resolution source make it all the way to the screen
* Auto 16:9 enhanced mode renders anamorphic DVD content in letterboxed widescreen, using all available display lines for the image
* Sony's Digital Reality Creation (DRC) circuitry and Direct Digital Circuitry create rich, natural-looking images from any source
Amazon.com Product Description
Dim the lights, fire up your DVD player or HDTV receiver, and let Sony’s 51-inch Hi-Scan KP-51WS520 turn your living room or board room into a movie theater. The set uses Sony’s HD Microfocus CRT and lens system, featuring smaller phosphor particles, thinner phosphor layers, and other improvements that give the set a beam spot 28-percent smaller than Sony’s standard CRTs. And that means sharper focus, higher contrast, and brighter images. The screen features a wide, 16:9 aspect ratio that matches the dimension of most movies and HDTV broadcasts, and the KP-51WS520 is compatible with standard-definition 480i, enhanced-definition 480p, and high-definition 720p and 1080i sources.
The set’s HD Detailer wideband video amplifier provides high detail from high-res images to give you the best possible image from high-bandwidth sources. Auto 16:9 enhanced mode with auto ID1 detection automatically renders anamorphic DVD content in letterboxed widescreen, using all available display lines for the image and wasting none on the black bars that frame the image when a program’s widescreen aspect ratio differs slightly from the set’s.
Digital Reality Creation (DRC) circuitry ensures high picture resolution, while proprietary Direct Digital Circuitry increases a video signal’s signal-to-noise ratio before it reaches the DRC circuit, ensuring rich, natural-looking images from any source. TwinView 2-tuner PIP (picture-in-picture) lets you view any 2 sources simultaneously–even 2 TV stations. Sony’s MID-X (Multi Image Driver) maintains the integrity of a digital signal by minimizing image loss in the scaling process.
Sony’s CineMotion 3:2 pulldown detection and reversal is a handy feature for watching progressive-scan movie programs in their native 24-frame format. Digital video mastering introduces a common distortion when adjusting 24 frames-per-second movies to 30 fps video; 3:2 pulldown digitally corrects this distortion, removing the redundant information to display a film-frame-accurate picture.
The set offers 2 different digital video interfaces: a Digital Visual Interface (DVI-HDTV) and an HDMI (High-Definition Multimedia Interface), each of which permits a direct digital connection with a compatible DTV set-top box. Other connections include 2 component-video inputs, 4 composite-video inputs, 3 S-video inputs (with 1 each composite-/S-video on the front panel for ready connection to a camcorder or gaming console), and 2 RF coaxial inputs and 1 coaxial output for hookup with an older VCR, cable box, or antenna.
What’s in the Box
TV, remote control, remote batteries (2 AA), a user’s manual, and warranty information.
Product Description
Indulge in Hi-Definition as it reaches new heights with Sony’s KP-51WS520 Hi-Scan Projection Television. Featuring 16: 9 Hi-Scan 1080i Display and Digital Reality Creation Multifunction circuitry, the KP-51WS520 produces beautiful picture resolution for your viewing enjoyment. The KP-51WS520 also features a HD MICROFOCUS CRT and Lens System, CineMotion Reverse 3-2 Pulldown Technology and Flash Focus Auto and Manual Convergence. Elevate your entertainment experience with the KP-51WS520.
