If the heading didn’t give it away, I’ll insult your intelligence:
I just did the Maxima/Altima (180sx) upgrade to the front of my s13. Now, can the same be done to the rears? I know that the 180sx has 240sx rears, but thats not my question.
What I wan’t to know is if I can do the Maxima/Altima upgrade to the rear brakes, and if there are any problems or consequenses. And if not - WHY.
Well for starters… you wouldnt have a working e-brake
2ndly… i’m pretty sure (not 100%) but the bolt locations to mount the caliper are different from front - rear… meaning a front caliper wouldnt fit perfectly on the rear “you may have to make an adapter for it”
2ndly… i’m pretty sure (not 100%) but the bolt locations to mount the caliper are different from front - rear… meaning a front caliper wouldnt fit perfectly on the rear “you may have to make an adapter for it”[/quote]
i think you misunderstood. he wants to use the Maxima/Altima REAR rotors and calipers on the rear of his car.
Well… to be honest there’s not real point, aside from maintaining the bias if you’ve upgraded your front calipers.
Having good high quality rotors and pads on stock rear calipers is about as good as you really need to go. Anything oversized or with more pistons is in my oppinion overkill for the amount of work the rear brakes are ever going to encounter. If you really want to up the “performance” of your rear brakes Gas slotted and X dimpled (not drilled) rotors are the best choice. Combine that with a high end brake pad, such as EBC green stuff and you’ll be locking the rear with the hand brake and stoppingon a dime going backwards.
The reason I say X dimpled is that X drilled rotors tend to overheat around the drilled holes and cause the rotor to warp, where a dimple work in a similar fassion to the gas slots.
You don’t need to go crazy with the rear brakes. But you might have a squishy pedal is the bias is off from front to back.
I also have a question then. If you have the z32 upgradfe on the front wheels, do you need any upgrade on the rear to maintain a good brake bias…if so what kind of upgrade?
If you did the Z32 swap front & back… you’d have one real soggy brake pedal
I’m running a Z32 MC with a 180sx front “until I get around to swapping in my Z32 front & rear stuff” and stock rear setup and its awesome “pedal is so firm” remove the MC and its an instant change but even without the MC its still an awesome setup with alot of braking force (without any bias issues)
S13GG is running a Z32 front setup with a stock rear-setup (he was running the Z32 MC until it crapped out) but even now that hes back to the stock MC hes not having any “bias” problems
I can second that. I’ve got z32 fronts and stock rears. s14 w/ABS (slightly larger MC). Pedal feel is great. ABS works and fronts lock before rear brakes (okay bias). Somebody ran the math already (good guide too):
Scoll down a bit and there is a economical and simple setup for the rear brakes. I tried once but did really feel like getting shit machined. http://www.saltgod.org/terry/terry.html
