for
grand national/turbo regal guys’
heres the skinny
Guys here is the info on the tranny class. So you will understand the list includes the basics and a few things that are highly recommended. Call me if you have any questions. When I finally nail the exact date down I will let you know. I’m doing all I can to do it quickly as I know the longer you have to make travel plans the easier it is. I strongly suggest you find a junkyard 200-4R to bring as a doner in case you have any failed hard parts. I collect parts, I do not sell parts. TR’s are really brutal on hard parts and they are somewhat expensive. Try to find something from a caddy or other granny car as 95% of the hard parts are the same and those kinds of cars never see any excessive torque. Even if they are classed as “bad” its usually just burned clutches and seals and the hard parts are usually still good. Going price for a bad 2004-R is usually 75 to 100 dollars and if it turns out you don’t need it I will buy it from you when you leave.
The tranny build up we will be doing will be a considerable improvement over the stock unit with altered shift points, quicker shift performance etc. To arrive at the final version I bought five transmissions from reputable TR vendors as well as a brand new ASC built GNX tranny and completely disassembled them. I compared what each of them did. If everyone did a particular mod I copied it. If some of them did it I only considered it based on cost and/or reversibility. I carefully considered interaction of different combinations and the possible side effects. The result is a clear step up from stock and pleasure to drive. To date about three dozen guys have gone through the school with total success.
We start noon sharp on Friday and finish late Sunday afternoon. In theory it could be done faster but with several guys that have not ever been inside a tranny its a miracle that it can go as fast as it does. And someone always brings a “zinger” that needs special attention. There is a lot of work and we all have to help each other in a team effort. It can be a lot of fun if you enjoy working on your turbo regal. You will need a room for Fri and Sat night. There is no charge for the school and all special tools will be provided. You have to bring your parts from the following list. You can buy them wherever you choose but I have provided a good low cost source to consider. I need to know in advance if you suspect your tranny has any serious problems that might need special attention or parts.
anyone interested pm me
