2015 Project- 99 Formula/TA-LQ4-88/83-T56- 2016 Project 93 Formula Road Race Car
After I spun a few rod bearings on my LS1/Nitrous setup in 2014, I took a year off to plan and purchase parts for the turbo build. I basically copied Matt Happel’s (denmah) Fairmont 5 combo since I was so impressed with the number is made.(I don’t plan to run meth so curious what I can make without it). Drew helped with the tune to get it running and I will be making a visit in the spring to finally get it tuned once the fuel system is installed.
Details Below
99 Formula Converted to a Trans Am(Front Bumper was last piece)- Ashen Gray Mettalic.
03 LQ4- Stock parts with Gapped rings, New Bearings and all ARP Hardware
Ported 241’s with Dual Springs. Ls9 Head Gaskets- Chinese Studs.
Trick Flow 216/220 Cam.
On3 88/83 T4 Turbo. Stock Truck Manifolds flipped. All DEI Wrapped.
Twin Emusa 38mm Wastegates and Emusa 50mm BOV. 4an feed-10an Drain
Mike Norris Catch Can- Hallman Boost Controller. AEM Wideband
CX Racing Intercooler with Piping Kit.- 4" exhaust with Dynomax Bullet Muffler. Fender Exit on Driver’s Side.
(2) Derale Pusher fans/Griffin Radiator Stood Up/EFI Source 3 Bar MAP Sensor
Rebuilt T56 with Monster Stage 3. 4.10 Gear with 295/55/15 MT’s
**Current fuel system 255 Pump with 80lb’s- Have Holley EFI Rails, Another 255 with Hobbs switch, Upgraded Wire Harness and -8 Feed/-8 return going in the spring.
Started with ryanbgb22’s down pipe from his first build. Converted it to twin wastegates.
http://i133.photobucket.com/albums/q59/firehawk496/IMG_5449_zpsedljjd8p.jpg
Motor/Trans in. Radiator Support
http://i133.photobucket.com/albums/q59/firehawk496/IMG_5854_zpsectuh6dr.jpg
http://i133.photobucket.com/albums/q59/firehawk496/IMG_5857_zpsqzlg0t0r.jpg
http://i133.photobucket.com/albums/q59/firehawk496/IMG_5943_zpsyu7ou20d.jpg
http://i133.photobucket.com/albums/q59/firehawk496/IMG_5891_zpsxrioxlgl.jpg
http://i133.photobucket.com/albums/q59/firehawk496/IMG_5888_zpssu3aowl3.jpg
http://i133.photobucket.com/albums/q59/firehawk496/IMG_5944_zpsc9px7jpn.jpg
http://i133.photobucket.com/albums/q59/firehawk496/IMG_5948_zpsbioa1gqa.jpg
New Bumper Mocked Up
http://i133.photobucket.com/albums/q59/firehawk496/IMG_5919_zps15bscgy8.jpg
http://i133.photobucket.com/albums/q59/firehawk496/IMG_5917_zps6yz2mwrf.jpg
Just About Finished
http://i133.photobucket.com/albums/q59/firehawk496/IMG_5903_zps9feqmqhg.jpg
Exhaust Ring from Monkey Fab I ordered. Gave thanks to my friend’s who helped with the motor build, paint, fab and install.
http://i133.photobucket.com/albums/q59/firehawk496/IMG_6224_zpsxopnpmxu.jpg
http://i133.photobucket.com/albums/q59/firehawk496/IMG_6225_zpseko2jxep.jpg
http://i133.photobucket.com/albums/q59/firehawk496/FullSizeRender_zps5ul0cymm.jpg
2016 Project
93 Formula Road Race project.- After taking laps in a friends Z06 racecar at the Glenn this summer and having the CNY raceway Park 15 minutes from where I live, I picked up this 93 Formula roller. It’s already got a Wolfe 6 Point roll bar and harnesses. This will be a LS Based motor with a donkey dick cam, T56, Dumps, gutted and resprayed white. Should be a full on Hoonigan type car when it’s done. Burnouts and Donuts for days.
http://i133.photobucket.com/albums/q59/firehawk496/IMG_6130_zpsoyqadffy.jpg
http://i133.photobucket.com/albums/q59/firehawk496/IMG_6129_zpsx5bm84ys.jpg
http://i133.photobucket.com/albums/q59/firehawk496/IMG_6134_zps5iram1fv.jpg
:tup: road racing, what series and class?
I’ll be honest, I will be doing some trackmaster classes late this year, early 2017 to get started. I’ll be looking to do some track days or SCCA racing in the beginning of 2017 and see where it goes. Should be a fun build and street car when it’s done.
I love your car. Looks amazing
nice! always exciting to see another car being built for road racing/track events. i would recommend getting a fixed back sparco seat or some kind of equivalent though. most organizations require that for use of harnesses. and itll keep you in place so you arent slamming your knees off the door panel and cage…from experience lol
Wow this is a beaut f body. Have you and lz locked in a grudge race yet?
Whos tuning it? Any dynos?
wait a sec, do you have an exhaust tip on it? What size dp do you have and what is the size going out the fender?
Looks awesome Doug! Seriously, by far still my favorite color on ANY car around, I love it. Let’s get you up to Buffalo this summer, been a while.
Also, huge thumbs up to road racing, super awesome! You’ll enjoy it I’m sure.
Nice. I was thinking about that manifold the other day and wondering if you ever did anything with it. Glad to see it went to a good use at a good home.
Nice setup!
Choda-
Not locked in yet but I’m sure I could make a trip out!
Talking to Drew about tuning it in the spring after the fuel system goes in and I can go more than the 7lbs it’s on now. I’ll buy dyno time from his buddy and turn the wick up.
And it’s a 4" downpipe with a 4" bullet muffler out of the bumper. We cut the tip around the contour of the bumper. Not sure I like it yet. I also doubt the muffler is doing anything since it’s such a short run. I may just redo it with 4" stainless pipe.
Gennaro-
Thanks man. I will get a hold of you when I make the trip out this year.
Ryan-
Thanks again for the hookup on the DP. Worked well on the install after a few modifications!
Couple of Shit Vids of Idle and 2nd/3rd gear passes on 7lb’s taking it easy. Should be able to shift around 6300-6400 once tuned on more boost.
https://youtu.be/oYmXGbplsKI
4.10s and big boost, should be a hell of a ride!
I am sadly more excited for the white car than the gray one :tup:
This car looks nasty! What ever happened to that Firehawk you had?
I’m going to get the rest of my F-body front suspension soon so you can have that kmember/whatever else you need.
The Firehawk actually went to Buffalo and was returned back to stock for the most part. It’s also barley been driven. I miss that car!
And thanks LZ!
Looks great! Between you and LZ I’m starting to get some motivation to work on my shit.
