215/70/15 tires on 7spokes
anyone mounted 215/70/15’s on a 92 base or se? (superhicas sits lower in the rear im told)
does it fit ?
thanks
Yea they should fit, on stock suspension at least, might rub in the front
HAHAHA, I think thats what I ran the one year I got brand new free toyo observes (on my 92 hicas), they came off an oldsmobile cutlass (1991 2 door IIRC)
they fit, but rubbed the fender liner, and once while turning I hit a large bump the front susp compressed, and the tire bit the fender, as I was turning enough for the tire to poke out from inside the fender.
If its a beater, do it. But watch the driverside steering wheelwell, there is a very important section of wire harness in there.
thanks for the info
