So I’ve been looking into this for awhile and I think I want to re-lip my own wheels.
Now, from what I already know new lips for the dish blah blah blah but the part I’m stuck at is cutting the lip free from the barrel, I have 3pc welded.
Anyone with experience on this topic? Do I just go at er with a grinder/dremel or do I have to go the route of a horizontal lathe(not sure if this is the correct name for it)
Also, mods, if this is in the wrong section please move. I’m not hip to nyspeed
I would not DIY this. Contact MemoryFab or Spintech. They should be able to lend some help on the process
that said. I’ve split many sets of 3pc wheels for polishing and re-lipping. When I realized my SSRs were welded I lost all interest in refinishing them.
there is no functional advantage while in use over a same spec one piece at this point. the big pro points are you can rebuild parts due to damage or wanting a different size. they also allow manufacturers to have standard parts they can build many options from. they’re also easier to manufacture, but possible with more labor.
the future: (oem grade and lower pricing, while stiffer):
Like other one piece monoblocks and welded two piece, they’re constructed from forged aluminum and not cast. Therefore, lighter and stronger material as well
If the wheels are any good I would find a way to cut em apart, otherwise I prob wouldn’t bother.
The cost of cutting them apart (whether it be time or money) plus the cost of having custom lips made is most likely a good chuck of the cost on a new set of wheels.
