335 tire on a 10.5" wheel?
wheel and tire guru’s, need some quick help. Looking at some 335 30 ZR 18 TOYO PROXES RA1 tires and they are too cheap to pass up. Only problem is, I know a 10.5" wheel are a little to narrow. My question is, can it be done SAFELY?
These tires blow. But yeah, they’ll fit ok.
It’s close but should be ok
i had the same setup on my 91 ford escort gt.
I also read on ls1tech that these tires run wider then their actual size.
The only speed(s) SSS will run from are dependent on the tire on the car!:rofl
the tires are way to cheap to pass up. IMO its worth a try.
DUH!!
these tires are a drag radial I guess.
They should hook well actually
I have read a few reviews on them on ls1tech with guys making 500rwhp + and they hook great I guess. Even arent bad in wet conditions.
I would buy them in a heart beat, I am just concerned about the size for wheel fitment and on the car fitment.
Buy them, if they dont fit resell for a profit
In the process of clicking BIN. Thanks.
theres 10 lots of them dude. Your not going to affect me if you do.
I would buy those in a second if I had wider wheels.
Just bought all 10.
You don’t need tires, you need a belt sander to fix that motor.
Bro, there are only like 2 machine shops in the US that can build those things.
Good thing its going back to stock.
RA1’s aren’t drag radials. The sidewalls are made to take a high cornering load, as they’re an R-comp track tire.
People consider them effective as drag radials too.
