Nice decently broad curve from 3700-6000rpm range. Looks like it could easily have more beyond the 6k point unless that motor can’t spin any faster. Which I think would be a bit odd for a modern 4 cyl.
Thanks fellas for the praise. The car definitely needs to be rev’d a bit more, but I think to get serious revs out of it, it would need to be de-stroked.
Clutch upgrade is a must. This is an ACT full faced disc. Handles quite well and is not overly aggressive on the left leg.
Stock bottom ends hold well on these 2AZFE’s so long as the tuning is not too aggressive. The conservative tunes like in the 11.0-11.5:1 seem to hold very well for quite sometime and abuse. Longest boosted time frame I have on one of these cars is 1 year and 5 months daily driven and weekend tracked 2-3 times a month.
The bottom ends should be considered to be set in forged internals if your goals are 350+. 300-350 seems to be the danger zone for things breaking (especially rings).
The cars drive pretty much stock, with a little bit of compressor surge when people elect the Stage 5 turbine wheel on idle. The 550cc actually idle pretty damn good on this set-up for sure. I was impressed the 1st time we did it. The secret to good idles and response is the VAC lines and the BOV used. We tried a few different ways, but this configuration is the most favorable.
