update post 11
hmmm might be intrested pm me your bottom price without the trans…
Compression is 136, I think on cly #3, the rest were a pita to get to… It drove 180 miles perfectly on less than half a tank. Oil pressure and temp were right where they should be. Definitely needs spark plugs though, the gap was pretty big when we pulled the plug to do the compression test.
ballpark?
300 pulled and delivered. Its in Kennedy NY
slam on the brakes why dont ya. haha.
i was with travis on the drive down. shes a runner
BUMP. make me an offer. still in truck, but the front end is off so it should come out easy!
this has got to go!
how many miles? I have a 96 S10. Needs a clutch and a starter. if the miles arent bad I may just pick this up and make it a weekend project.
I have no idea how many miles are on it. I forget what the cluster said. but it was replaced at one time, The person I bought it from said it should have about 60k on it.
are you doing a direct replacement? The harness/computer/some sensors wont be avail from this motor
I do have a 4.3 tbi motor set that you can have the harness/computer also. http://www.nyspeed.com/forums/showthread.php?t=72046
bump. this motor will be heading to the scrap pile soon
COME GET THIS!!!
available all day friday and saturday. then again the weekend of the 29th
please buy this. its beginning to be more of a burden than anything else.
I will be taking off the oil pressure sending unit and temp sensor part to use on my s10
BUMPO
going to the junkyard soon. someone come get this please
what kind of shape are those wheels in? and how much for just the wheels. are you yanking the hopshock and such from it or is that available too?
I am keeping the wheels. What do you mean about hop shock? Never heard of that before
there should be brackets on the right side of the frame and the axle with a shock connecting them. came on later v6’s and the zq8 package. not sure if this one has it since its a 4 cyl, but does it?
Akaik it just has the sway bar and regular shocks.
