My truck came with ABS, (First production truck with 4 wheel ABS). Anyways, i’ve always had the power disconnected from it. All my sensors on the wheels are bad. I believe they’re about $700 each.
I want to remove the ABS unit, and run new brakes lines in its place.
Can i get it inspected. Will a vehicle that’s supposed to have ABS, but doesn’t, pass inspection.
IF you are worried about it, just pull the bulb from the cluster where the ABS icon is. I pulled my whole ABS setup, including the main harnesses, and I don’t even think anyone noticed. My car is OBD1 so it doesn’t get scanned though.
well my ABS light doesnt come on, unless i plug the harness to the module, so if i delete the module, and replace the brake lines, no light should come up.
the only time the light came up was when i plugged the power to the module, and the dash light came on, and it threw all the codes.
