ok so im driving 92 s13 240 and when i hit the brakes,even on pavement the abs kicks in and starts-a-tapping…good?? not good.:wall: when the car is on its way to stopping the car stalls. i know this could mean a number of things but i am wondering if anyone has had the same problem and found out why. thanks in advance.
Abs is supposed to tap away… Not sure the problem there.
Stalling when coming to a stop is a symptom of a vaccum leak, though it could be numerous things.
Could even be your battery if there is a bad connection. My postive terminal slipped off in the winter beater and when I hit the brakes it used enough juice to cut power to everything and stalled it.
my car stalled like this one time too, when i didnt use the clutch at all.
Maybe that is it?
