Ok, I have a problem and its going to be difficult to explain. Hopefully somebody can identify it.
Ok, so when I start to drive, first and second are very hesitant. So what this means, is when I push on the gas and rev it past 2k rpm. The car seems to drop a few rpm then go up then drop, its a very slight drop wouldnt even notice on the tach. But anyways, its annoying, and I am very paranoid that something is going to break.
Check MAF. Will the car let you go past 2500 RPM? Because I believe if you disconnect the MAF or there is a bad signal from it the motor will not let you go past 2500 RPM, as it is in protection mode or something like that.
:lol: well that always helps. :P, then yeah spray your engine bay down with some soapy water and check for bubbling around it, then wash your engine down. It’ll help you locate vacuum leaks. Make sure to keep it running though while doing so.
spraying brake cleaner around all the vaccum lines while the car is running works better, if the idle picks up, wherever your spraying the cleaner is being sucked into the engine there.
