Hey guys,
My car is getting worse mileage than it should right now. About 400 in the city, sometimes less which bugs me.
One thing I notice alot recently is that my idle is wacky… doesnt ever dip below 700 although sometimes it chills at around 1000-1500 then slowly drops back to 700 and very VERY mildly fluctuates in that area which I think is normal. there is barely ANY change thats not my concern. My concern is why it is sitting at 1500 for a while. That is for sure wasting gas.
Next thing, I know I need a tune up. I did put all new fluids in everything in the car. Although I noticed a rip in my air intake right near the intake manifold/throttle body. I believe air is either escaping or leaking in. If it were leaking in and bypassing the MAFS then that would mean I should be running lean, which is not the case, I believe it’s running slightly rich due to higher fuel consumption rates. And because of teh pressure of the air being inducted through the intake I do believe that air would only escape and not enter therefore still getting a wrong reading from the MAFS and causing it to run rich.
The problem also persists under breaking. When I shift to neutral I can see that the RPM is at 1000-1500 and stays there then eventually drops.
Also, occasionally when I see this I try to revv a bit to see if it’ll go down. But whether in gear or not, when I rev it’ll come down to around 1000-1500 and stay there just as before.
Just a side note if it matter or helps you picture it in your head, it is an SOHC motor.
Another problem I have been encountering is while braking and coming close to the stopping point, doesnt matter if im in gear or neutral the car seems to virate alot in different areas enough for me to vibrate myself a bit in my seat while deccelerating between 2000-idle (700) or it does that stupid thing where it chills at 1500, either way I get the vibrations.
Another sidenote is that my motor mounts are in pretty bad shape and I am sure that causes some vibration in the cabin aswell.
I think thats pretty much it for now.
Any and ALL help is appreciated. I know there are plenty of tech guys who I’m sure over the years have encountered this problem, so please post and try and help me out here.
p.s.- Sorry for the loooong post, I just like to be as descriptive as possible.
Thanks,
Dan
