************* Adam’s 2JZ powered s14 Build Thread *************
I got this car with the swap already done but all the wrench turning and assembly was below my standards so I am rebuilding all of it.
When I bought the car it made 497rwhp @ 17.5 psi tuned by Dynamotorsports (Tony)
My goal is 600rwhp minimum for daily driver/summer car
Here is what the car looked like when I got it
Started it up one morning and heard a misfire so I did a compression test, every cylinder was amazing 160-165… except #6 it was at 40 psi
I then did a leak down test and heard the intake valves leaking so I knew they were bent or stretched so disassembly started…
Pistons still look like new after being cleaned
Parts before powdercoating
After…
Ceramic Coated Turbo manifold
Cylinder head back from CCH
Putting it back together…
Block surface prepared and ready for headgasket
Here I am torqueing the headstuds
The tranny is an R154 from a Mk3 supra. The shiter is a C’s short shifter which has a rubber bushing inside… I wanted a solid shifter feel so I modified it, shortened it, machined a solid bushing on a lathe then welded it back together. Special thanks to my homie Drew for always letting me use his shop
Drilling and Taping the valve covers for custom breather lines… deleted PCV system just venting to atmosphere
Exhaust is 2 feet of 3" downpipe to 4" all the way to the back to a Vibrant muffler… I welded up the muffler without having the car at the shop… I just positioned it at home and put in a bunch of shims and got lucky I guess
Engine bay semi complete… still need more parts I just put it together with old parts so I could start it up
Here is a little video of a couple small rev’s
http://www.youtube.com/watch?v=ubnbpG4dFs4
Still lots of work to be done, need more parts… will be posting updates soon!!!
Any comments or suggestions greatly appreciated
I couldn’t post in the build thread section… can someone move it please?
