I want to put a new wheel on my car since my old one marks up my pants, and i just dont like it.
My question is, i have cruse control, well had cruse control, it dosnt work anymore. I can just take off the wheel and cut everything but the horn wire, then hook that up to the aftermarket one, there is nothing overly special about it? thanks
It is a bit more complicated then that. If you have airbags it would be a good idea to disconnect your battery first, then you can remove the wheel, cut all the wires, attach the horn wire to the new wheel, the turn signal cancels won’t work anymore unless you modify your hub as well. I can give you more specific information if you are stuck on anything.
