Since apparently I like beating dead horses into the ground…
THIS:
7 Faults Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
***********P1297 - 35-10 - *- *- Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
***********P0300 - 35-10 - *- *- Intermittent
16685 - Cylinder 1: Misfire Detected
***********P0301 - 35-10 - *- *- Intermittent
16686 - Cylinder 2: Misfire Detected
***********P0302 - 35-10 - *- *- Intermittent
16712 - Knock Sensor 1 (G61): Signal too High
***********P0328 - 35-10 - *- *- Intermittent
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
***********P0420 - 35-10 - *- *- Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes *******Labels: 1C0-907-37x-ASR.lbl
**Part No: 1C0 907 379 K
**Component: ASR FRONT MK60 *****0103 *
**Coding: 0018945
**Shop #: WSC 00066 000 00000
2 Faults Found:
01276 - ABS Hydraulic Pump (V64)
***********014 - Defective - Intermittent
***********012 - Electrical Fault in Circuit
It’s pretty much self explainitory, any advice? I’m more so looking at the engine than the ABS, I could care less if I had ABS or not.
The way things are going this car will be for sale within weeks.
Thanks,
Chris
Paulo
October 21, 2009, 3:07pm
2
Should have bought my BMW lol.
Tim
October 21, 2009, 3:09pm
3
I told you it was nothing but trouble! :lol:
Sounds like a problem with the seats.
Nyspeed I give you Chris’ crash course run with VAG products lol.
Paulo: I know lol
Tim: I know lol
Will: I know lol, wait…no that doesn’t make sense lol
Maxwell: It sucks lol
time to sell it? i told you the new seats were going to be nothing but problems.
should have kept the blazer. lol
Ugh that blazer was the bane to my existence lol.
If this sells I’m parting out all the aftermarket crap. Profit lol
Wow you should have bought my gti.
I know, if I wouldve had 2k more in cash I couldve avoided a lot of problems.
This shit sucks
AShort
October 21, 2009, 7:24pm
11
does it run like shit? coil packs? injectors?
are you planning on selling it?
VR2000
October 21, 2009, 8:20pm
13
probably need new coil packs or check the spark plugs on those cylinders, as for abs i know yu said you could care less but check the wiring thuroughly at all 4 wheels
not really but it stutters at idle occasionally, also when i pump the brakes which i think may be a vacuum leak somewhere
ask me that after this next paycheck lol, i’m about to move to florida and DD my bike lol
yeah I’m going to replace the coils/spark plugs regardless, plugs are 11 bucks online for NGK and I can get 2 used coils from my friend pat (the kid with the blue GLI) so i’ll see if that clears up and then run my vag-com on it
