Airbag Warning light on...
I took my front seats out a few days ago to fix a tear in one and the heater in the other, and to just give the interior of my car a thorough cleaning before winter.
I just put the seats back in and now i have an AIRBAG light on in my cluster… I rechecked all the wire connections since there were only 2 per seat, and they are all in place.
2000 audi a4 1.8tqm.
I was very gentle with the seats and none of the wires ever got even slightly tugged.
What should i do?
also, will it pass inspection with it on?
it will pass inspection.
Take the bulb out haha.
don’t get in an accident? :o
Does it have that passenger auto detect thing?
did you start the car or turn the key to the on position while the seats were disconnected, if so it turns the SRS light on.
find some one with vag com cough cough and have them reset it for you
yes, i installed a new MAF while the seats were still out, then turned the key on to scan and erase the MAF code with my obdII scanner. oops.
COUGH COUGH COUGH COUGH COUGH COUGH
(does this mean you have one?)
ya I got one if your south towns you can swing by my work,
Siefert Auto at 1212 abbott, (just ask for the VW/audi specialist)
if your north towns you can meet me up at my home… if thats the case Ill pm you that address.
i’m just outside of OP so i’ll be in touch!
can you detect which ABS speed sensor is bad with Vag com too? lol that’d be great.
yes, Cel, ABS, Airbag… I can even change your lock settings, your alarm beep…
swing by im normally there 10-6 but only half day tomorrow as i have to pick up a motor.
so monday would be the next best. or give a call 783-8228, ask for britt tell her when youll be in (she is my wife) if you come in around 6ish I can shoot the poop longer…
oh no shit… that sounds fantastic. monday would probably be the better, and around 6 would be best. i’ll give a call monday.
The airbags will still work even if the light is on, FYI.
