there’s nothing that can be done, i had some track pads on and they would set off alarms. i put some OE raybestes and then cooked those @ the track and those now squel. All those aggressive pads gotta be breken in properly
Bought a set all around for my R33 and they are garbage for the street. I was told they were gunna be quiet from a seller on the forums. Rain or cold they were supposed to be quiet, and I get nothing but people staring at me at stop signs and lights. I was very disappointed in the way they perform for the street, even after doing proper wear in process they squeel like crazy after a bit.
I say boo erns if your using on the streets! And giver if your using for the track.
hp+ pads will always squeel no matter what, ran them on my skyline and they never stopped squeeling got them on the 240 now and the exact same thing. theres not much you can do but learn to live with it or change them, but the only way i did find to make the squeeling stop periodically is to soak them with water
thats how HP+ are, and its still not as bad as true dedicated track pads LOL… honestly stop whining, they stop AWESOME for the street. I had them on my previous z32 setup… loved it for what it was.
You always gotta compromise comfort, cooling, friction, noise, dust here n there with pad choices…
If you can’t handle/like the noise go for some HPS pads… they are a street pad. HP+ is an aggressive street/autox pad.
I have run hp+ for over 2 years, run through them twice. They are epic on the street. I know they squeal normally on the street.
The squeal im getting from my new seat of rear pads is like 20 times louder than normal, hence i started this thread.
Normally the pads squeal around 5 km/hr just when ur at the lights, mine start fucking screaming at 30km/hr, so loud that you can hear them from a block down. That shit ain’t normal. Real high pitch screeching. Not the normal hp+ screech.
So my question was in regards to the abnormal screech im getting out of my new set of rear pads.
Plz don’t reply to this thread, if your just gonna talk about how loud hp+ pads are in general, as that isn’t the issue.
brakes still grab hard and everything works at high speed braking and high force braking, the noise is only present at low speed braking. No scars or gashes or anything on my rotors to indicate any other problems. Starting to think that the pads are just contaminated.
