I need some professional advise. Please read this post on neo and let me know what you guys think, thanks for any help.
Ryan
There’s a fair bit of misc. info around this forum, do a search on “auto manual” and check the sites recommended to this guy as well:
http://www.son240sx.ca/forum/viewtopic.php?t=13407
Good luck.
Factory Service Manual
Manual Transmission
Shifter
Release Bearing
Pressure plate
Clutch
Flywheel from a m/t
M/T Mounting plate
Flywheel Bolts (m/t bolts are longer than a/t bolts)
Clutch pedal
Brake pedal (From M/T car)
Clutch master cylinder w/ resevoir
Clutch slave cylinder
Clutch hydraulic lines (Main line, bleeder line, rubber line to slave cylinder)
Drive shaft front & rear section
Adapter bolts & nuts for mounting crossmember to the 5 speed (2)
Reverse light sensor, Neutral position sensor, 5th gear sensor (on side of 5 speed)
Lower shift boot & plate
Upper Shift boot & Finisher plate.
Locked but only after you got helpful advice anyway.
You got lucky this time lazy.
