baffled oil catch tank?
who makes a baffled catch?
i don’t want moroso because it vents to atmosphere and i don’t want the home depot diy.
does anyone else make one that comes baffled?
im sure there are some out there, i have also seen people put steel wool or something similar (it wasnt as fine as steel wool)
i bought an $8 ebay special, and im very happy with it
steel wool is a HORRIBLE idea. you need more of a breather system and metal baffels welded in the can not steel wool. your best bet would be a direct line to exhaust with a one way check valve or an open breather system
:word: race style evac… CHECK VALVE NECESSARY, and a breather on the valve cover… race style evac only works when there is ZERO backpressure, creating vaccum in the CC… breather should stay dry using this method
(breather)…but is necessary for when BP is preventing vaccum pull…and the CC needs to relieve pressure
definately NOT steel wool
I made up a baffled can & breather setup for my turbo2.3 car. $15-20 & a trip to Home Depot.
and, read:
http://www.nyspeed.com/forums/showthread.php?t=10061&highlight=baffle
http://www.nyspeed.com/forums/showthread.php?t=10060&highlight=baffled+catch
thats a nice diy, but i don’t weld. also yours vents to atmosphere. i’d rather not do that.
i’d really rather just buy a baffled one. i heard arc might be. still can’t tell and they are too pricey.
i was thinking in to the intake, just before the s/c…shouldn’t that create enough vacuum?
also, what do you think the max length on hose could be? i want to get it far in the front and low so it is as cool as possible for condensation.
http://www.saikoumichi.com/DC3_page.htm
that looks clean.
THANKS!
