i have this nasty belt squeal that i cant get rid of i changed my belts cause i though that they were worn out it went away for awhile,
but now its back i used some belt dressing and that seemed to help a bit but now its seems to have no effect
the altenator is new
i ran my car with no power steering but it didnt go away when i did that either
so that leaves me to belive that i might be my waterpump
but that catch is that once i rev it up and keep the revs up or im driving over 1000 rpm it goes away and then after awhile of driving it stops squealing
Take a bar of soap out to the car, start it and then rub the soap against the inside of the belt. Be carefull though as you wouldn’t want to see your hand go threw a pulley. You could also just try increasing the tension on the belt.
i dont know how to drive and blew a shift and bent 3 valves the motors only running on the front 2 cylinders but hopefully threre will be a newer one in tomorrow
belt dressing makes the belt sticky, soap and candles just makes it quiet, but doesnt cure the belt slippage. I used a candle on a 94 talon i used to have… regularly :lol:
