How do I shut up my squeeky belt
Not sure which belt it is, but its annoying as hell! It used to be only squeeky when its cold, but now, Its happening more frequently, at low rpms, and sometimes it travels on to high rpms getting louder and louder if I floor it. The only time it doesn’t squeek is when I hit the accelerator really gently. I think its the alternator belt, but I’m not sure, it may be lose or something. Any one have any suggestions to this problem and how it can be solved?
Lube them up if your cheap, if not, get new belts.
Heh heh… candle wax
i heard that toothpaste works (this is heresay by the way)
Lube them up, come by my place if you want and I’ll help you out.
tighten the stupid thing…
Problem Solved.
