Best thing to stop a leak in my rad
Alrgiht whats the best thing to do to stop a leak in my rad, its no bigger then a pin needle and is on the plastic ontop just right of the intake hose (if your looking at the car from the front) I dont have the money or the time to put a new rad in this week.
Any ideas
Open your rad cap and crack an egg into it while its cold.
Then imediatly run/drive your car for a min of 10-15min.
really? How long does that hold for?
Does it fuck anything up?
should hold up for a while.
I dont think it does anything bad, ive seen tests and no bad outcomes were reported.
Although it is plugging up a hole so i assume it may gum up the insides of the engine a bit.
you can buy stuff from canadian tire or wallmart that you throw in your rad and it fixes small leaks, dono what its called.
^^^ Rad Stop Leak
You can use those and they work well.
I just figured it was late at night and he needed a “qick fix” and CTC isnt open late.
It will line the coolant system with a small film. No harm done by it.
Just if/when you replace the rad do a quick coolant system flush.
Duct Tape :lol:
sorry i had to!
Thanks guys (Y) im gonna put that ct stuff in and then try to get a new rad in before sunday.
LoL …it does work good…didn’t you guys watch myth buster
How does and egg work to fix a leak?
it will cook into the hole :slight_smile:
