Best way to remove injectors?
i need some advice.
I am in the process of installing my 370cc injectors in a s14 with the ka24de engine , Do i Need to take the fuel rail off or can i just take off the caps and pop them out?
help is appreciated ?
I have heard popping out sidefeeds is a bitch. Be very careful not to break the electrical clips or damage the injector body itself.
Some people have some tricks to do it… I haven’t tried it yet out of fear of breaking something.
leave the rail on the motor, take off the injector caps, then put just the cap screw back in the rail, and use a flat head screw driver that will fit in those small holes on the side of the injectors, and lift up using the screw for leverage.
if they’re stiff coming out try twisting the injector back and forth in the rail, and prying up from both sides.
I used allen keys and a punch/all type thing and use something for leverage…
I pryed from both sides…
I just ripped them out, and then Kicked some ass,
are you going to have something to control the fuel from the 370???
so you guys are saying that the little hole tha go right through the injectors that i shouldf just pry them out from there,…
and i have a safc 2 to controll the injectors
