Boost controller and gauge?
Hey I wanna run two
Boost gauges and a boost controller where
Would I hook up sr20 det I kno boost controller Goes on wastegate but is it bad to have 2 gauges hooked up
it might be a problem to run 2 boost gauges, especially if you were using 1 line for too many things (ex. FPR and 2 boost gauges)
the only way to use 2 boost gauges is if 1 moniters the compressor outlet pressure and if the other gauge moniters manifold pressure…but you would only need to look at that info once to verify that there is minimal pressure loss in the intercooler piping…you would know if you’re driving the car and you pop off an intercooler pipe
