Im confused…Which brakes? 240 or r32? Front or rear? There’s only two bolts to remove in order to remove the caliper. Which half is stuck? The cylinder body portion of the caliper, or the torque member (the kinda horseshoe shaped part that holds the sliding pins)
I’m not sure what clips you are reffering to…maybe the pad retaining clips?
The bolts that you took out, were they 14mm or 17mm?
You may have removed the carrier bolts rather than the caliper bolts, they are 14mm and located at the back, top and bottom. Removing these will allow the caliper to come off. then the pads come out, then those stainless steel clips you are talking about will come out.
You may need to re-install the 17mm bolts into the carrier (also at the back, but closer to the center) to make this happen easily.
No, sounds like you have done it correctly so far… you sometimes have to pry the caliper out of the caliper carrier with some rocking back and forth.
The 17mm bolts don’t have to come out if you are just doing pads. If you are removing the rotor, you have to take the carrier off.
Once the caliper is off, the pads will slide out (again with maybe a slotted driver) of the clips, then the clips will come out (again with a little messing around but no bending should be required).
alright, so do you have the caliper completely off the car or just off as if you were doing a brake job? when i took my calipers off (completly off) i took the pads out and those clips practically fell out, yours may just be siezed in place? maybe spray them with some penitrating fluid and get under them with a flat head? dont know if that helps but good luck
im not doing a caliper swap, brake pad swap or anything like that
i just need the rotor off so the caliper needs to come off first
ive taken calipers off before, its only twop bolt. not hard.
but there these metal clips now that i havent seen before and the cliper wont budge with them in place. there sandwhiched in between the caliper and another part of the assmebly. what its called is beyond me.
i just need to know how to get these metal clips out. ill have pics up this friday.
