I’ve been working on the brakes for a while and still no braking power.
Today I replaced the front calipers to s14 ones because my old bleeder screws were mangled. Bled all the lines with the help of another SON member and still ZERO braking power. I’m at my witts end.
I replaced the line running across the pass side fender about a week ago, no leaks that we can find…
The lines are all completely bled, we have triple checked this and ruled it out as a possibility. We are also no longer losing any fluid in the master/anywhere.
Pedal is mushy as hell after bleeding, it’ll stiffen up while bleeding/pumping when the car is off. If you stop pumping, and press it again, it goes to the floor.
Zero brakes while the car is on/driving.
I think we’re gonna try bench bleeding the MC, and see if that does anything, but with the amount of fluid we put through it bleeding it, I can’t see how there is possibly air in there still…
when u bleed the brakes are you starting the furthest away from the master and also are you pumping them up opening the bleeder then closing the bleeder? then pumping again? so your not sucking in air?
Does the peddle go to the floor? what do you mean no braking power. If it feels like they aren’t bled, check to make sure you don’t have calipers on the wrong side. Bleeder on the top not the bottom.
Ya calipers are on right. Pedal feel is decent at best when the car is off after pumping a few times, but when turned on… nothing. No braking power as in, the calipers are not closing…
Ya the pedal goes to the floor when the car is turned on. When off anf given a few good pumps it stiffens up a bit at best. The calipers are on the right side and are on correctly.
is it a s13
i had this porblem with my s13 i remember, every time i bled it like 10 times kept trying different things, then went on the computer and found out there is a sequence u have to bleed in, when i followed that sequence it worked. so yea find a fsm or something and find out the bleeding sequence. myns had abs didnt work with the sr thought but yea try findint the bleeding sequence. i think it is something like this not sure thought . rear drivers side, then rear pass side, then front pass, then front drivers.
