alright so when I apply pressure on my breaks everything seems fine, but when I continue to hold it it will slowly start to fall towards the floor, if I pump it this happned faster. So basically it is loosing pressure.
I did put new calipers on the front over the winter and blead them so I am really not to sure why this is taking place.
Sounds like a leak or air in the system. When you bleed the brakes start with the longest brake line (Rear driver side I think) then move your way upo to the shortest line (Front Driver Side)
na I just Bled the fronts becasue there were the only ones that I changed, well looks like I am going to do that hole sucker tonight.
anyone around to help. it is a bitch to do by your self.
I think the Air system is alright but I am going to doubble check it tonight
Sounds like you have a leak somewhere. Are you noticing your brake fluid level in the MC dropping? When driving do the brakes pulsate or just seem slushy? If you’re loosing fluid from the MC and the brakes feel weak (but not jerky) you have a leak. So start checking all the conections, lines, MC, calipers.
You have a Z32 conversion right? A lot of guys have small leaks when using PDM lines up front.
If not, it might be air in the system but from what you’re describing it sounds more like a leak.
Not quite, S13’s bleed in this order.
Left Rear , Right Rear, Left Front, Right Front …then Front ABS, then Rear ABS if you have it.
na no leaking, the breaks feel totally fine and awsome when I first step on the Pedel. it is just with constant pressure that it totally starts to fade away. then I let it go and then come right back to normal. and I have also not notices any fluid drop. I have reaplaced the calipars before and never had this problem.
I have yet to get them installed, but, I got their ss lines front and rear for the 300zx conversion… LEAK?! WTF?! They cost quite a bit and so what are saying?
the fluid might be in the booster, when the m/c seals fail they often dump into the booster, but it’s possible that air is also getting back into the system the same way
