Brake rebuild?
is there any shop near brampton that rebuilds brake calipers??? i try’d serching but no luck.
Do it by yourself, it’s very easy.
how???
srry for being a noob
Remove the Piston… Remove the Seals.
Sand Blast or Hand Sand the Caliper to clean it up.
Install new Seals.
Install Piston.
Done.
Look it up online… its very simple and extremely straight forward. Rear Calipers will be a bit more tricky because of the Ebrake Bypass/Assembly thing but its still doable all on your own.
