car not moving
hey guys this is a pretty wierd situation here. i push the clutch pedal in put the car into gear begin to release the clutch and apply gas and the car does not go anywhere. the clutch itself is fairly new, it’s a center force stage 1 clutch. it was leaking fluid but if i were out out fluid it should not go into gear with out any problems or without making any sounds, im stumped.
is your ebrake on? brakes seized? can you put it in gear and let the clutch all the way out without it doing anything?
im not that stupid lol the brakes are brand new and in working order, e-brake is good,when i release the clutch it just revs up and doesn’t even feel like it is trying to go anywhere
adjust the engagement point under the clutch pedal…
also make sure the master has been free’d of air pockets…
does the pedal return to the top properly when you let off? Try what varun said. Bleed the whole system and if you still have the dampener loop remove it.
did u put the fork back on? or maybe the pivot broke…
also try adjusting the clutch master.i had to back mine out all the way for the rps stage two…
Its your pressure plate. thats the final answer.
So the shifter is in gear and you completely let out the clutch pedal and nothing happens?
Termites chewed your input shaft.
