Hey, I bought Vinay’s old integra, and for some reason whenever i press in the clutch to put it into neutral the car will randomly stall out. Other times it will just bog down like it is going to stall, but then the rpms will pick back up to idle. Again it only seems to do it when i shift into neutral, does anyone have any suggestions of why this could be? Also he said the clutch safety switch had been deactivated. Thanks
does it idle real low when you start it?
my integra used to do that too, but I knew it needed a tune.
that car is running neptune correct?
Bring it into synapse. I know vinay wanted to get some thing with the tune touched up but never had time. Im sure morgan could fix it in 5 minutes
bring the car down, well look at it and take care of it if its a tuning issue. i know neptune came out with some updates a while back to handle a similar issue. i cant recall if vinay’s car was tuned before or after that.
It was tuned at the end of last summer miguel
yeah, didnt know if it had something to do with the tune or not. But he did suggest that I had it retuned. I will swing up there monday or tues. Thanks
