car wouldnt start...
i try to start my s13 and all i hear is click click click click click untill i release my key… could that be my starter?
if it is how much will it cost me to change???
You can buy a starter for a lil over 100. Its not that hard to install, you Kind of need to get under the car though. It’s more likely the battery, bring it into a Wal-Mart or something and ask them to check it out for you first. If it’s not the battery, it’s probably the start solenoid, tap it with a hammer when tryign to start it, see what happens.
push ur car as fast as u can, hop in, let out the clutch, when the car bogs put the clutch back in while hitting the gas and ur car should probably be started
im assuming its 5spd. Bump starting is good!
what he said… but put it in first or second, clutch the car… roll it to as fast as you can at least above 10km/h to make sure it starts… if your good you can drop the clutch, start the engine and release the clutch… leaving the engine idling and out of gear… but u can also drop the clutch while rolling downhill when its in gear and it should start.
