I’m just looking for some suggestions on o-ring chain care products.
ok, go!
ok, go!
Chain Lube:
http://www.rockymountainatv.com/productDetail.do?navType=type&navTitle=Chemicals&webTypeId=34&webCatId=23&prodFamilyId=4287
or
http://www.rockymountainatv.com/productDetail.do?navType=type&navTitle=Chemicals&webTypeId=34&webCatId=23&prodFamilyId=3224
and as far as chain cleaner i"ve used a couple of products and they all seem to do the same job:thankyou:
i personally make the best lube on the market. I can come over if you make an appointment and lube it up real nice
its true but the only way for him to do so is if you stand next to your bike bent over the seat naked…:gay3:
wellll… i’m kinda writing a paper right now…
edit: fuck it, i’m free ![]()
kersosene or wd40 to clean the chain
bel-ray chain lube is the only thing to use. i’ve tried just about everything and this is by far the nicest. lasts a long time, doesn’t fling off, and is white so it’s obvious when it’s wore out. i got mine from bob weavers i think.
+1
Yep Bel-Ray
I use that on my ATV is works like a charm
