Have you ever used the Dupont chain lube? You will def like it, been using it for a few years on my o-ring chains! Its a great product and last a long time.
My chain maintenance is notoriously horrible and neglected. Often I’ll spray the chain and just take off without waiting for it to dry and I rarely clean them.
I’m hoping this brush will allow me to clean the chain well in between the Teflon application.
That’s a sweet brush. I need to clean my chain today, I covered it in a thick coat of BelRay white lithium chain lube when I put the bike away. It still got a bit rusty tho. I use the 'ole toothbrush and kerosene.
Problem with the Tirox thing is that it’s only $16 normally. Which is half decent considering grunge brushes are ~$10 and cleaner is around ~$5, however I either have to get Tirox shipped from Canada or England or seemingly the last store in the USA (which I did) and shipping alone is $8
Walmart. $5 for about 1 gallon (I think it was a gallon, might’ve been 1/2 gallon). I only needed like a pint of the stuff, so I’ve got a lot left over. You can have some of mine if you want.
Here’s some pics from cleaning the chain today. Tools used: Kerosene, 1 tooth brush, 3 rags, and dupont chain lube
Before: Chain was coated in a thick coat of white BelRay chain lube
Where do you get your info from??? You never soak a chain (assuming its an o-ring chain) in gasoline, kerosene, etc. You can use kerosene to clean the chain but long exposure will ruin the seals on the chain.
