hey, its cold now(-30ish) and i decided its time to change my altenator belt, i was wondering what things i should look for precautions i should take to do the change over? suggestions would be great thanks!
Should be a quick job. There are just two bolts I think. Loosen them off and switch them, then tighten them back up.
Unless you have to take some of the other belts off… shitty tme to do belts.
Haha I just did this, twice.
Assuming you mean the ka24e…:
Loosten the big belt nearest the front of the engine bay. Slide it around the fan, and out of the way. If you have a fan shroud, it will all be more difficult. Take it out i guess. Yeah so once that is off, you need to loosten the top bolt on the alternator (facing foward), the bolt facing sideways right beside that one, and the bottom bolt. The alternator should slide side to side now. I’ll assume you know what to do after that.
Good luck!
Jeff
ha, thanks! will i have to tourqe any of the bolts or just tighten them decently tight?
DAVE I NEED TO SLAP YOU FOR NOT KNOWING HOW TO CHANGE YOUR BELT
(SLAP, SLAP, SLAP)
one slap is from me one is from allen and the other is from evan
p.s. we are hammered right now ![]()
(SLAP, SLAP, SLAP)
p.s. we are hammered right now :D[/quote]
LOL - BUT… He did vice grip his throttle cable once!! :lol:
hahahaha. well rob iv never had to worry about it before so i never knew, but NOW I DO. hahaha
