clicking noise
ok when i first start my car up and go turn the wheel to leave where its parkerd no matter what way i turn i hear a clicking noise?? and it sometimes happens during a drive when i turn… any ideas?
cv joint,
should i get it looked at asap?
How loud is the clicking? if you are clicking when going strait then you should get it replaced asap.
no just when i turn
look and see if the boots are ripped, they probably are
as told by another source… my car is to new to have ripped boots… i have a 2005 grand prix GTP
Check the boots
[quote=“97Ranger,post:7,topic:30109"”]
[/quote]
The “source” sounds like an idiot.
[/quote]
not really.
put it in neutral and turn while moving, if there is no clicking its the cv joints
dont just take some dude’s word for it, take the 2 minutes to look for yourself, jesus
the cv joint will still spin in neutral so this will not work
I don’t see how it can be anything but a cv joint. Also, just because the boot is not torn does not mean that the cv joint is fine either.
[quote=“93dx–hatch,post:11,topic:30109"”]
[/quote]
when i had a bad cv on my old civic it only clicked when it was in gear :gotme:
ok when i leave the house i will look at my boots and check do the neutral test
[/quote]
I still say brakes, or a wheel bearing.
[quote=“97Ranger”"]
[/quote]
[quote=“Daddie,post:2,topic:29864"”]
Do you not know how to place threads in correct forums?
Just wondering.
[/quote]
You’ve used up all your freebies. (moved)
[/quote]
Yeah it will, there is no load on the joint in neutral.
[quote=“13005TEDGP,post:16,topic:30109"”]
[/quote]
he would hear it all the time then… deff cv
[quote=“eMKay,post:18,topic:30109"”]
[/quote]
yes but the cv joint will still be turning if you go from driving at 40mph then put it in neutral.
regardless, get under there and check the boots
