Hi, im pretty sure the clutch on my 92 S13 is stock so…
the clutch engages really high off the floor and I mean really high. Is that normal? anyway to adjust it?
Thanks alot!
Thanks alot!
yeah seems normal, depends on how you like it, if its too high for you there is a threaded rod behind your pedal with a bolt on it, the bolt is for adjusting the engagement point, your bolt will be almost at the tip of the rod thats why its engaging at the very top…
want to adjust play with the bolt
Thanks alot man! Just wondering what is yours or other people prefrences for engagement points?
i generally like em as close to the firewall as possible,
better for driftin
really didnt know… I have mine set pretty high but nothing ridiculous, its in just the right spot for me. I had it down low and it just felt weird, had it up top and it wasnt right either, I like to have about 1 inch of play up top i would say.
