Well my truck was running fine last night then I went to start it this morning and it will not shift into gear… clutch pushed all the way in yet it wont shift into gear, i can put it into gears when the truck is off but as soon as I start it no go… help please, thank you.
clutch master/slave cylinder most likely. is there any clutch fluid leaking out under your clutch pedal?
And I bet if you put it in gear, push the clutch in, then try to start it the truck lurches right?
Clutch isn’t disengaging.
If it’s hydraulic start tracing the line and see if you’ve got a leak.
If it’s cable operated make sure the cable didn’t snap.
I’ll check it out thanks for the advice… btw its hydraulic
