i did a 5speed swap to my s13 about a year ago. The car is totaly stock except for the air intake. It has  ran fine and pulled normal since then. Now just a cuple days ago the clutch started to release like 1intch befor it hits the floor and will grab right away when i release in gear. When the car goes into gear it pull’s fine and downshifts fine, but the clutch won’t pop bak up, you have to use the back for your foot to bring it back. Also when you bring the clutch back after shifting you can hear a slight scraping noise, almost a tick.
Could it be the clutch line just needs to be bleed? or could it be somthing internal to the tranny? Im stumped.
re-bleed the system and see what happens…
but when the clutch pedal isn’t popping back up, it usually means your slave or master cylinder is on it’s way out…
could be clutch slave cylinder related after u bleed it try gettin one if its still not fixed there like 40 bucks new i think it was and also u can adjust the pedal inside the car but thats just for the height might help !!!
