alright guys so i changed my clutch everything is ok except for two things. i brok one sensor on the tranny i dont noe what it is but i dont think its a biggy cuz everything is in working order my check engine light is on.
when im in first gear and am pulling the rpms a little to almost 5k i noe im not supose to but i heard a strage sound so i did and when im in about 4k im hearing a strange sound its like something is spinning freely but when i shift it goes away and everyitng is fine. any ideas/ suggestions? thanks
mikey
but if your clutch stopped working, first thing to check is the slave line. Well, check the clutch master cylinder and see if there’s fluid period. Then see if the slave line is leaking.
If your clutch is gone,
well, there’s no tricks to a 240 clutch, it’s just like any other RWD car.
Make sure your new clutch and pressure plate assembly comes with an alignment tool, get the flywheel resurfaced
Where is the pedal engaging/disengaging the clutch? Is it very low to the bottom or higher up. If your clucth is grabbing VERY close to the bottom of the pedal then you need to adjust the pedal because chances are you not disengaging all the way.
