my clutch was stuck half way between the floor …happened sauturday…checked the fluid and it was good…
well after that i psrked the car and drove it yesterday…any ideas or do you think it might of been a fluke
Originally posted by slowcamaro
my clutch was stuck half way between the floor …happened sauturday…checked the fluid and it was good…well after that i psrked the car and drove it yesterday…any ideas or do you think it might of been a fluke
i odnt know about yours on your car!!
but i have the same problem with mine when i get on it tends to stick to the floor
but mine i have to do this to fix it
http://www.installuniversity.com/
go to
McLeod Adjustable Master Cylinder and “Drill Mod” Install
i know on the ls1 you gotta to this and then update to a 2002 parts
98-99 had problems with there hydrolics
Mine was doing that when I first brought it out this spring. After running it for a bit it stopped. I asked Brian and he said that was normal.
mine does that all the damn time!!!
that where i found the drill mod talked to afew poeple that did it and never had a problem
they said do that and upgrade to a 02 slave! so im gona give it a whril as soon as the new clucth gets here!
check your floor mat ! :tounge:
crankwalk…
