Hi guys,
I need some help, I installed clutch master clutch with 600miles on it for my s14 Ka. I bled the system by presses in the pedal few time then holding it down and releasing the bleeder on the slave. I’ve done it over 15 times but i still cant get pressure. I’ve replaced the pivot ball, release bearing, slave, master cylinder and ss lines. I also dont have the dampener box. If i have the rear wheel up in the air i can get it into gear since it has no load on it but cant when its on the ground. I also have the rod adjusted to the fullest as well(pedal highest point).I need help badly guys
