Ok, this is just cool. Sorry, for it being in text, I only have it in PDF format.
What do you guys think?
DB
2013 Bi-Fuel CNG Silverado/Sierra 2500HD Extended Cab
When it comes to managing budgets and keeping an eye on the environment, business owners and fleet managers alike face many challenges.
That’s where GM’s 2013 Bi-Fuel Silverado/Sierra comes in. It’s designed to help businesses reduce their fuel costs and environmental impact.
ENGINEERED BY GM
· The Bi-Fuel Silverado/Sierra HD Extended Cab uses
a proven, 6.0L Vortec V8 engine with factory-installed
hardened intake and exhaust valves and valve seats.
Unlike aftermarket solutions, the engine and all CNG
fuel system components are engineered to meet GM’s
rigorous standards for reliability, dependability and
safety. GM’s validation tests include: full barrier testing
(6 separate tests), 10 year corrosion, mud trough, water
fording, hot weather evaluation (including trailering),
cold weather chamber testing, altitude testing and fuel
gauge accuracy, among others
· The system automatically and seamlessly switches
from CNG to gasoline when the CNG tank has been
depleted. It also provides the flexibility to manually
switch between the two fuels at any time
· The 17 Gas Gallon Equivalent CNG tank and 36-gallon
gasoline tank provide a combined range of more than
650 miles1
· The CNG fuel tank is mounted in the truck box, just
behind the cab, and is bolted to the truck’s frame.
A Type 3 CNG tank is used to minimize payload
reduction and maximize usable box space. It is
protected by a durable, aluminum diamond-plate
cover, with easy access to the CNG filler receptacle
· The CNG bi-fuel option is available for long or standard
box models, in both 2WD and 4WD, and all trim levels
BACKED BY GM
· The Bi-Fuel CNG Silverado/Sierra HD has a
comprehensive 5-Year/100,000-Mile Powertrain
Limited Warranty 2 and a 3-Year/36,000-Mile
Bumper-to-Bumper Limited Warranty2
· The CNG fuel system, unlike aftermarket solutions,
is backed by GM’s Limited Warranty and is
serviceable by Chevrolet and GMC dealers, the
largest dealer network in the U.S.
· All CNG fuel system parts have GM service part
numbers for dependable availability, providing you
with the peace of mind that parts are available to
keep your vehicles on the road.
· Bi-Fuel Silverado/Sierra HD has available factory
OnStar®3 including
2013 Bi-Fuel CNG Silverado/Sierra 2500HD Extended Cab Specifications
Model Availability Chevrolet Silverado/GMC Sierra 2500HD Extended Cab,
Regular or Long Box, 2WD or 4WD
Silverado model numbers: CC20753, CK20753, CC20953, CK20953
Sierra model numbers: TC20753, TK20753, TC20953, TK20953
Engine (LC8) 6.0L Gaseous Fuel–Ready Engine
Power Gasoline: 360 hp @ 5,400 rpm SAE Certified; 380 lb.-ft. torque SAE Certified
CNG: 301 hp @ 5,000 rpm SAE Net; 333 lb.-ft. torque SAE Net
Transmission (MYD) Heavy-Duty 6-Speed Automatic
Emissions Certification Federal and CARB
C02 Emissions Reduction vs Gasoline 15%
Payload 2,865 lbs.(*1)
Fuel Tank Capacity, GGE (Gas Gallon Equivalent) 2 Gasoline: 36 gallons
CNG: 17 GGE
Estimated Maximum Combined Range(*2) 650+ miles(*3)
Fuel Tank Locations Frame mounted in cargo box, just behind the cab
Manufacturer Warranty (includes full CNG system) 5-Year/100,000-Mile Transferable Powertrain Limited Warranty(*4)
3-Year/36,000-Mile Limited Bumper-to-Bumper Warranty(*4)
Emissions Warranty Subject to individual state regulations
Options Required (LC8) 6.0L Gaseous Fuel–Ready Engine
(FHV) Bi-Fuel CNG Fuel System
*1 Maximum payload capacity includes weight of driver, passengers, optional equipment and cargo.
*2 The vehicles may be filled at either a 3,600-psi or 3,000-psi station. Note: Filling at a 3,000-psi station will result in a reduced amount of dispensed fuel and resulting loss of range.
*3 17 GGE CNG tank/36-gallon gasoline tank. Based on GM testing.
*4 Whichever comes first. See dealer for details.
©2012 General Motors. All rights reserved.
