after i changed my car battery the alarm systems been acting up. everything works but the starter function. i am unable to start up my car due to this. ive been advised that the solution to this would be to just take out the relay from the compustar unit. ive never done this before so im kinda iffy with it. if someone could swing by and lend a hand it wouldvery much be appreciated. should be a quick job. i’ll worry about replacing the unit or going after warranty when i can drive the car hehe.
u may need to re-program the remote to the brain, compustars like to get fucked up sometimes all u gotta do is relearn sometimes
on and off three times u will see the lights flash, hit button I
Hi,
We are an authorized Compustar dealer. If you want to come by we will check it out for ya no charge if you are a member
Thanks
Jeff Try
Audio Heaven Inc.
905 763 1686
