just put a new drive in it because i thought my other one was shot
fresh install of windows, after about 3 times being booted up i get a message when bios screen is loading
“no 80 pin IDE connector detected on second IDE channel”
it boots up, gets to windows and restarts
then i get, just after bios screen
windows/system/config cannot be found
could it just be my IDE cables? i dont see how it would mess up windows if its just the second IDE channel(extra HD and cdrom)
the first IDE channel is just my boot drive
any ideas?
I have tried this with 2 different harddrives, a few different IDE cables and an ati 9200 just incase, all giving me the same thing after 2-3 times booting up
chris, did you check to see if the mobo manufacturer has any firmware/bios updates? Probably a long shot though. Do you have an old PCI IDE controller card to try? I may have one in one of those old boxes I got from work when they were junking them. Too bad it’s intel, we could of tried it in my box to see if it gave the same problems
well no one has suggested this yet, but if you havent checked them you may have a problem with the jumpers on the drives.
I dont know the make of the drives but WD and seagate have different settings for jumpers. I’d take a look at the configuration of the HD’s and the ROM. Try putting the two HDs in without the ROM drive, then check in the BIOS to make sure that they are detected properly. Put the ROM back in the check the BIOS again.
Barring that, try the drive in someone elses machine to make sure the drive itself isnt DOA.
on the first ide channel i have a WD(brand New) 40 gig drive set to CS
second channel: cdrom set to master and a WD 40 gig set to slave
just curious as to why it’s setup like that… I always throw my HDD’s on the first IDE, and cd/dvd-roms on the secondary. Should I have set it up like that? You know more about that kind of stuff than I
yea i have the bios set to autodecect drives and it seems to be(or lists the drive anyway)
i’ll try both the HD’s on the same channel, but usually with any of my gaming comps i run windows drive alone on one IDE and the drive with the games on the second IDE
steve come over today and give me a hand, one more brain never hurts lol
cdrom only on both channels see what gets recognized… if both channels can see the drive there is a really good chance they work… if they both work, leave the cdrom on one of the channels its really not important, which one its on.
plug in the main system harddrive to the cable… the first in line (i think thats the master slot if they are both cable select) boot it up see if the drive is recognized. if so good. stick the other drive on the end of the ribbon cable.
and it should all be kosher…
also you can boot off a pci IDE
but do the cdrom test to see if the channels are good
god i hate IDE soo much … i’m soo glad i’m all sata… IDE is nothing but slow bullshit
Might run into some problems there, I learned the hard way while trying to fix my dual boot issues that, on newer IDE cables there is a specific plug for Master/Slave.
On older cables you could plug either drive with either plug, it was the jumpers that mattered. Now though, the cables are built with job specific plugs, that is, the Master plug, will not work in the Slave drive and vice-versa.
