Connecting Rod Bearing
as the title says, i’m looking for a connecting rod bearing for a nissan 240SX,
if you guys got any or know anyone who has one or know where i can find one please let me know thanks…
ALSO…the motor is an sr20det…i did an engine swap recently…i found the bearing in the oil pan of the sr20det… and once it was installed there was low compression i got new connecting rods but i couldnt find bearings it looks like only the forth cylinder is messed up so i would only require one bearing but to be on the safe side i would like to replace the others, which im told are not 100%. The top end of the motor is fine and the turbo is in top shape, but i am concerned about the bottom end. In your opinions what are the chances that the bottom end of the motor is also messed up?
http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&from=R10&_trksid=m37&satitle=240sx+bearings&sacat=-1%26catref%3DC6&fmmk=&fmmd=&fylo=&fyhi=&mppfqy=240sx+bearings&sargn=-1%26saslc%3D2&sadis=200&fpos=T6H1K3&sabfmts=1&saobfmts=insif&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=1%26fsoo%3D1&coaction=compare&copagenum=1&coentrypage=search
oh my post whore …
thanks
i really dont think you need to post the same thing in every section
i didnt post in every section i posted it in the appropriate sections of this site
as we are in “general auto chat” right now i pretty sure it fits here,
i posted it in RWD Technical chat cause it also fits there
posted in Car Related Goods it also fits there
then in NECC Sponsers which it also fits there
you see if i were to post it in the every section it would also be in “Events”, “Misc”, and “NECC MEMBERS ONLY”
7 new threads? A little excessive.
